I have been having issues with my new pc lately when it comes to turning on. After hours of tinkering i figured out that the pc only starts if the monitor is disconnected prior to hitting the switch. this issue even happens from sleep. I am hoping theirs an easy fix for this as nothing i have tried has worked. Thanks for your time!
https://linustechtips.com/topic/610659-pc-startup-issue/
Probably a faulty displayport cable. I had this issue before where my computer refused to start unless I unplugged the displayport cable.
Turns out the thing was completely dead, but in your case it's just perhaps faulty.
Try using a new or different one to see if it helps.
https://linustechtips.com/topic/610659-pc-startup-issue/#findComment-7901054
