I'm thinking about making a Mini ITX build and need some case recommendations. I was thinking of using the Node 202 but I'm not sure I can get by with only 2.5 inch drives just yet... :/
Any recommendations for Mini ITX and very small cases that have at least 1 3.5 inch drive bay?
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
https://linustechtips.com/topic/610108-small-cases/
I use a Corsair 250D, but I wouldn't call it "very small".
Rather than try to find a case that takes your 3.5 inch hard drive, why not consider replacing the HDD with an SSD, or a 2.5" laptop HDD.
Check the properties on your 2TB drive and see how much space you are actually using. I did that and ended up replacing my HDD with a 500Gig SSD.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/610108-small-cases/#findComment-7891245
I've just looked and actually 500GB SSDs are a lot cheaper than I thought now...If I get an external drive then 2*500 or a 250 and a 500 could probably be manageable...
https://linustechtips.com/topic/610108-small-cases/#findComment-7891301
Even though my 250D has room for 2 x 2.5" and 2 x 3.5" drives, I ended up using an 120 Gig M.2 boot drive (on the back of the motherboard) and a single 2.5" 500Gig SSD. :)
https://linustechtips.com/topic/610108-small-cases/#findComment-7891318
