Was using blender when my PC
Day before I had installed the beta drivers.
I was modelling, when I pushed pushed a vertex up, I accidentally tapped shift key or Ctrl key(don't remember).
My PC went...well take a look at the image.
It was a gpu problem, so I logged into safe mode and used DDU to clean the drivers.
But during the installation of the latest drivers, i.e, Crimson 16.3.2, my screen went black and it stayed black for some time and then the pc turned off. When I turned my PC back on the drivers were not installed.
Again I tried installing the latest drivers and again my screen went black, but this time it was for a long time, and when I reset my PC, it went black after the windows boot screen.
I repeated the process of uninstalling and installing and I get the same results.
Tried reseting windows from advanced
recovery.
Tried using AMD's 15.7.1 drivers.
Specs:
GPU- XFX R7770
CPU- AMD A10 5800K
RAM- 4GB.
OS- Windows 10.
https://linustechtips.com/topic/610040-problem-with-xfx-r7770/
recovery.
Specs:
GPU- XFX R7770
CPU- AMD A10 5800K
RAM- 4GB.
OS- Windows 10.
Looks like it's dead. What were they temps before?
https://linustechtips.com/topic/610040-problem-with-xfx-r7770/#findComment-7890448
1 hour ago, Narigaur said:
Did you download the correct driver for your card?
Yes
Nope, and I am certain I have not been using it to do strenuous task like heavy gaming or rendering. And I have never OCed this card.
In this month I have only played World of Tanks on medium settings and used blender, and in that I rendered pretty low poly stuff that usually took 3-4 mins to render at max. Pretty sure it's more of software issue. Still I will consider it to get it checked in some other PC if possible by next week if the error persists.
https://linustechtips.com/topic/610040-problem-with-xfx-r7770/#findComment-7890735
11 minutes ago, Mogambuh said:
Yes
Okay. No problem. :)
https://linustechtips.com/topic/610040-problem-with-xfx-r7770/#findComment-7890769
