I have some questions and problems i am having regarding the voltage. I have been stable running intel burn test at 1.165 at 4.5 before doing all the changes in the bios. After doing the tweaks i had to push the voltage to 1.175 to run Intel extreme tuning utlity it ran fine for 5 hours. Then i started to run prime for 24 hours, for that i had to push the voltage to 1.190 to run it for 24 hours. Now i am having issues with games like bf3 in some maps it does a heavy lag. I have checked temps fine with cpu on load 45 and gpu's are fine as well. I am pretty much trying to figure out what is my stable voltage so i can do a offset voltage.
Currently My Voltage is at 1.195 with ultra high llc, i raised the ram voltage to 1.55000 and PLL voltage to 1.80000
https://linustechtips.com/topic/60903-help-with-i7-3770k-overclock/
You might want to check what your actual voltage is when running prime. I know for a fact that it is not at 1.195.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
1.195 in bios and in CPUZ it shows 1.200 when surfing websites. Full Load will run prime its at 1.208 So i am not sure exactly what to do.
Anybody?
3770K @ 4.5GHz is Prime stable at less than 1.2V?!
https://www.youtube.com/watch?v=GQNKbnHC1wQ
Intel 3770K @ 4.4GHz (Summer) - 4.6GHz (Winter) / Asus P8Z77-V Deluxe / EVGA GTX 680 /w Arctic Twin Turbo II / 16GB Corsair Vengeance @ 1866MHz / Samsung 840 Pro 128GB (Steam) / OCZ Vertex 4 128GB (Boot/Office/Steam) / Seagate Barracuda 2TB x2 (RAID 1, Storage) / Asus Xonar D2X / OCZ 1250W ZX / H80i /w 2 x Gentle Typhoons / Cooler Master HAF X /w Pioneer Blu Ray, Aerocool V12XT, 4 x Cooler Master MegaFlows (Red) / Logitech Z906, G930, G19 & G700
Yes Prime 95 is stable at 1.195 Voltage maybe less i cant remember.
You've got a golden chip then!
It has ran stable in prime 95 at 1.185 as well. But i raised the voltage to 1.195 but i am trying to figure out if my LLC is correct and if i should raise more voltage
LLC is fine. It will mean higher idle temps, but slightly better load temps and much better stability. If you're 24/7 Prime95 stable, don't raise your voltage any more.
I wouldn't say golden chip. You can put phase control back to optimized, you don't need extreme for tiny overclocks. PLL overvoltage can be disabled, again, small overclock.
Just put the vcore up to 1.22-1.25V and leave LLC to ultra high, try out a game. Make sure you're video card isn't overclocked at this time.
ok, did you have BF3 lag when running the clocks stock?
are you raising the CPU voltage to remain stable or what?
if P95 needs more voltage to be stable, then work on that platform, then retest on other
synthetics to verify stability. jumping around diff stress apps makes for long and
unsuccessful runs/passes.
make sure the RAM is set to 1600 (even if you have higher) and timings are correct
(should be the first thing done).
airdeano
Done, put the phase back to optimized and pll disabled and set the voltage to auto. Will test, thanks
airdeano
Ram is set to 1600 and timings are set properly. Also the voltage for ram is at 1.55000. In the bios its at 1.195 and its stable havent had any issues. But Battlefield 3 in some maps i notice  a heavy lag not smooth at all. GPU's are not overclocked either, after setting everything to default and test i felt the same stuff on ultra settings. I have ran tests to make sure hardware is ok and it is. Single player runs fine in bf3. I am not sure if its just the game.
Another problem i see is it could be my batterybackup. Its a apc batterybackup 550va and 330watt and i also have the monitor and other small networking devices connected to it.
I wouldn't suggest auto voltage at 4.5GHz... May run into temperature problems.
Make sure it isn't your internet connection too.
Voltage for PLL i set it back to auto, but i kept my cpu manual voltage to 1.195.
Could it also be my battery backup? as i mentioned above
Could be but I don't think so, find another surge protector and give it a try.
