Using Android phone as desktop microphone
By
The Falcon
in Audio
in Audio
Solved by Pesukarhu,
Download this app https://play.google.com/store/apps/details?id=com.ad960009.app.MicToSpeaker
Then connect your phone to your pc microphone/line in and use it as a microphone. So you only need your android device and a 3,5mm male to male cable.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
