Alright so i have an amazing pc titan x 5930k etc all the goodies thing is it doesn't seem fast for all the specs i got in it i have an ssd and steam games like tf2 still take like 30 sec to load before it use to be instant and i even fresh installed windows and restored it and it still takes 30 sec as to before it was instant and google chrome takes like 2 seconds to open and all that i have asus rampage 5 mobo and was wondering if there are any things i need to have enabled to have the fastest pc i could have maybe even one of you could remote desktop to my pc via teamster or something and check everything out thank you
https://linustechtips.com/topic/608958-help-with-pc/
39 minutes ago, airdeano said:
any what OS is it?
the install was on the MBR or GBP partition table?
any SSD/HDD RAIDS?
under the MSCONFIG>Boot>advanced options, how many cores are used for boot?
I have windows 10 on it and a samsung 850 pro and no raid just the ssd
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879899
38 minutes ago, airdeano said:
any what OS is it?
any SSD/HDD RAIDS?
I did not know I could set the number of processors. If it is unticked, does it only use 1, or does it use the max>
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879903
tick the 'number of cores' box and change to 4 cores.
have you installed the chipset drivers, intel engine management and the ASmedia SATA controller drivers (enabled, if not using it, disable)?
if not using the WiFi/BT, disable those in the UEFI.
verify the SSD is plugged into the non-SATA Express ports (should be ports SATA6G_1,_2,_3,_4, _7,_8,_9,_10)
default is ONE.
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879926
default is ONE.
you sure i should change it to 4 my cpu has 6 cores though?
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879927
1 minute ago, Hex. said:
Really? Now I am getting all giddy with the possible improvement. Is it the same story with the RAM?
depends on what the UEFI has designated the speed to be.. default DDR3 is 1333/1600, DDR4 is 2133. that'd be an unneeded dialog box to tweek.
1 minute ago, Devdyuk said:
sorry to bother you but will 6 make it faster?
no
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879931
no
thanks! i put it to 4 and how about the memory option in the advanced settings there to i have corsair ddr4 dominator platnium
nevermind just read the post about the ram thanks so much!
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879936
7 minutes ago, airdeano said:
have the drivers been installed for the chipset, intel engine management and USB3.0?
the windows unified drivers are meh.. using the aligned WHQL drivers can promote better performance.
i went to asus.com and found my mobo and upgraded bios chipset and all that
i never heard about intel engine management
also which engine managemnt for windows ten there are 3    5m, 1.5m and one more
i installed the 1.5 one i think which is the consumer one any other programs i need?
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879950
all of what.. it is important we know what exactly was installed..
use   MEI_V11.0.0.1155_20150709_WHQL_1.5M for the engine management driver.
what is the firmware of the SSD (use the samsung magician for this task)
for the ssd i have the magician its all up to date im using rapid more and getting really good speeds with it and i installed the mei 1.5 but is it an application or what i cant see it anywhere
this is the one i just installed https://downloadcenter.intel.com/download/26049/Intel-Management-Engine-Intel-ME-11-Driver-1-5M-for-Windows-10-for-Intel-NUC
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879977
4 minutes ago, airdeano said:
MEI is a driver with no application, runs on bootup/background.
how much RAM? how much virtual disk space used?
this is the one i installed is it ok? is it the right one? https://downloadcenter.intel.com/download/26049/Intel-Management-Engine-Intel-ME-11-Driver-1-5M-for-Windows-10-for-Intel-NUC
i have 16gb of ram
https://linustechtips.com/topic/608958-help-with-pc/#findComment-7879987
