4 minutes ago, jedinym said:
I'm going to buy a new monitor with the RX 480. Does the FreeSync function matter that much ? I know how it works, but what is the impact in gaming ?
It does when you are running games like CS:GO, where latency is frame rates (relative to real time) is critical
For an average gamer, playing things like GTA or just casual games, Freesync isn't necessary at all
I play CSGO semi-pro (college e-sports team) and I have never used a G-Sync (Nvidia version, which AMD copied) monitor and still never had a problem with latency
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/608684-does-freesync-matter/#findComment-7877016
Only you can answer whether you care about screen tearing or not. That's really all it comes down to. I just got a Nixeus Vue24B for $200 on jet.com using a promo code. That's pretty fucking cheap for 144 Hz + FreeSync. No reason not to get one if it costs the same as a VG248QE.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/608684-does-freesync-matter/#findComment-7877037
2 hours ago, jedinym said:
Thanks ! And do you think AOC G2260VW6 is worth it ? It's pretty cheap here. http://aoc-europe.com/en/products/g2260vwq6
@ivan134 @UberGamerKing
Not worth it in my opinion. The FreeSync floor on that monitor is only 48 Hz and want at least 30 Hz.
https://linustechtips.com/topic/608684-does-freesync-matter/#findComment-7877951
Average gamer playing games on average setup is where adaptive sync technologies are the most valuable, helping greatly with smoothness on lower framerates and reducing negative effects of dropping below monitor's refresh rate all the time because of not powerful enough setup. This is where FreeSync can be a game changer. For competitive gaming, where you have to have rig that can constantly run your game at maximum available performance, adaptive sync makes much much less difference.
This is very entry level monitor, but if you don't want to spend more money than get it. As for FreeSync range, check if FreeSync hacking works on this monitor, for example through CRU. You should be able to get it to around 30,35-75 instead of 48-75.
CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1
https://linustechtips.com/topic/608684-does-freesync-matter/#findComment-7878555
