So I'm looking at upgrading my case among along with a few pieces in the coming months and found my self perplexed with a few things.
First and foremost Is hooking up all of my fans.
I was originally going to use a molex to 3 pin adapter or a hub but found my self wondering how I would get them all to reach without extensions, and then figured I might not want them running at 100% all the time. And now I'm thinking of using fan controller.
So my question is. Can I use an adapter or hub to plug all my fans into and control their speed with some software? Or does any one know a nice fan controller that works with at least 6 3 pin fans? And especially some nice extensions since I more than likely will need those.
Parts I'm looking at getting.
4 of these total (2 intake at bottom 2 exhaust on top)
2 of these (both for front intake)
New Case
I'm also looking at trying a liquid cooler that I'm planning on mounting to the back and pulling air in for a positive air pressure goal.
Which brings me to another question. How well would would an H60 cool on an Fx8320 compared to a cooler master hyper 212 evo?
https://linustechtips.com/topic/608430-case-cooling-questions/
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/608430-case-cooling-questions/#findComment-7874401
phanteks has a pwm hub that runs off one 4 pin mobo connector and has 6 3pin headers (+2 splitters out of the box) that act as pwm
http://www.phanteks.com/PH-PWHUB.html
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/608430-case-cooling-questions/#findComment-7874405
120mm rads tend to be really bad at keeping things from getting hot so you might want to step up to a 240 or 280mm rad, and I agree that phanteks come with what sounds like a perfect solution for you, plus their cases tend to support larger rads
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/608430-case-cooling-questions/#findComment-7877535
Alright, well I'm liking the fan controller idea a bit more to easily keep my fans adjusted to the speeds I want. As for the liquid cooling uping to a something like a H100i is a bit over kill for my 8320, especially when I'm not really overclocking it. And I guess its cheaper to pick up an extra SP120 to replace the cool an quite 120 that comes stock with the 212evo.
I guess now the last problem I'm trying to figure out are cable extensions. So far I found these, but I'm wondering if there are some out there for a better price.
https://linustechtips.com/topic/608430-case-cooling-questions/#findComment-7879397
