I'm looking to do some (potentially dangerous program) testing in Linux Mint and I want to use a virtual machine, but first I want to make sure that it's completely safe and not connected to my PC or network in any way that could be a security issue. If anyone here is good with virtualization could you please tell me if my setup is ok or if you need more info. Host machine is Windows 10.
Screenshot of settings: http://prntscr.com/be3m48
Goal: Guest OS has no connection to Host PC or local network
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/608420-secure-virtualbox-help/
Make sure there is no network connection the between the host and the vm, you should be good after that.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/608420-secure-virtualbox-help/#findComment-7874271
