Hi!
I bought FX 8300 cpu with stock cooler. After I play game for few minutes fan goes to 5400rpm and it is very loud but temperatures are ok, about 50 C in load.
Is there any way to put some other fan from old pc or something. I want buy AIO water cooling but in this time I need solution for this. Thank you.
https://linustechtips.com/topic/608187-cpu-fan-problem/
3 minutes ago, vex_dm said:
Hi!
The stock AMD cpu are more shit that shit. Get a hyper 212
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/608187-cpu-fan-problem/#findComment-7871884
I wouldn't adjust the cpu fan speeds on an AMD chip.They are known to run hot.
I'd instead just invest in a 212 Evo. They are super cheap and cool super well.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/608187-cpu-fan-problem/#findComment-7871946
