http://www.phanteks.com/PH-PWSPR.html
Will it be able to keep up with 2x X99 CPUs and motherboards?
I will be using this 2000W monster: http://www.super-flower.com.tw/products_detail.php?class=2&sn=16&ID=119
Before you ask, I got it so I could throw whatever I wanted into the system, without a problem.
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/607860-phanteks-power-splitter/
2 minutes ago, Arc_Jester said:
It's just a splitter so it should have no problem at all.
Output Voltage
12V
5V
3.3V
Output type
Out1 | Out2
Out1 | Out2
Out1 | Out2
Inrush Current
160A | 160A
160A | 160A
160A | 160A
Normal Current
14A | 14A
14A | 14A
14A | 14A
Max Wattage
336W Total
70W Total
46W Total
Output Max Wattage
452W (system 1 + system 2 combined, gpu power consumption excluded)
There are specs, so what you put on it matters.
https://linustechtips.com/topic/607860-phanteks-power-splitter/#findComment-7868500
4 minutes ago, OddsCrazyStuff said:
Output Voltage
12V
5V
3.3V
Output type
Out1 | Out2
Out1 | Out2
Out1 | Out2
Inrush Current
160A | 160A
160A | 160A
160A | 160A
Normal Current
14A | 14A
14A | 14A
14A | 14A
Max Wattage
336W Total
70W Total
46W Total
Output Max Wattage
As I said before you're fine, unless you plan on putting some crazy OCs on the CPUs and adding like 10 HDDs the splitter won't have any problems. May I ask why though?
https://linustechtips.com/topic/607860-phanteks-power-splitter/#findComment-7868607
HDDs draw power from the motherboard and not the sata plug?
I'm not going with crazy overclocks, as I need stability, but I will still want around 4,5GHz on both.
As for why I'm going with splitter... I can fit 4 PSUs, but when I already got 1 that can handle it all, so does it seem pointless to buy more.
Case in question: http://www.performance-pcs.com/phobya-wacoolt-cube-1-medium-watercase-black-aluminium-edition.html
https://linustechtips.com/topic/607860-phanteks-power-splitter/#findComment-7868753
All the ports on a mobo require some amount of power to work + if you were using that many HDDs I would also assume a raid card is being used as well.
https://linustechtips.com/topic/607860-phanteks-power-splitter/#findComment-7868850
Its a dual motherboard setup. So 10HDD/SSD is not that that hard to use.
Not to mention PCI SSDs and such.
https://linustechtips.com/topic/607860-phanteks-power-splitter/#findComment-7868964
