Hi everyone!
I've recently updated my bios via MSI M-Flash and discovered that we can update the Intel Management Engine (ME) firmware as well. I've done some research on the subject but I can't really figure out wether or not it's important to update it. What's your take on that? Thanks!
https://linustechtips.com/topic/60707-intel-management-engine-firmware/
that is the software that controls cpu's frequency and voltage , ı usually keep it updated
It depends what hardware you have, it helps identify and install drivers relevant to your hardware and is seen on Intel boards, however it's strange that you have it on an MSI motherboard.
The Intel® ME software components that need to be installed depend on the system's specific hardware and firmware features. The installer detects the system's capabilities and installs the relevant drivers and applications.
Sam,
Intel Response Squad member
http://bit.ly/IntelRally
I would keep it updated in order to get the latest version that may fix some bugs. But I would update it in windows by downloading the MEI via the motherboard website and not via M-Flash.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
