I'm looking at doing a new build and wanted a few case suggestions and opinions for color theme. I'm going to be using the Asus ROG Maxiumus VIII Hero Z170 board with a G Skill Trident Ram kit for color theme and on the fence about the case choice. I'm currently thinking about going with the H440 Red and Black case, but on the fence because of the lack of gunmetal on the case. Just curious if anyone had ideas on cases I may not be thinking of. Budget wise I would like to stay $150.00 or under in similar size to the H440.
Motherboard http://www.newegg.com/Product/Product.aspx?item=N82E16813132565
Ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820231911&cm_re=g_skill_trident-_-20-231-911-_-Product
https://linustechtips.com/topic/606919-case-recommendations-for-color-theme/
Here's a full list of cases that will fit your motherboard as well as your red and black color scheme, are $150 and under, and are all mid tower cases.
https://pcpartpicker.com/products/case/#t=3&c=6,14,19,35,36,38,45,58,60,61,88&p=0&s=1&u=1&f=2,3,7&G=0,4&X=0,15327&sort=a8&page=1
I also made sure to include Gunmetal as one of the colors but I also threw white cases and cases with white accents in there just in case you wanted to see any of them. If you have any other questions then feel free to ask :D
Do you already own the Motherboard? IF not get the mATX Version of it and buy the BitFenix Pandora Silver ;)
A Phanteks Evolv ATX with a tempered glass window would look mighty nice! You could also get the Eclipse P400 which has a red LED on the front and comes in a few different colors that can suit your preference.
I like the look of the Phanteks Evolv ATX, had not considered it. Although probably not the tempered glass one, no one needs to see what lies behind the motherboard tray lol.
