So one of my 4 four homework tasks im finding very difficult this is it
Task 1
Write a program that converts any entered word into a code word using these rules:
-"egg" is inserted into the mid-point of any word of even numbered length
 -good becomes "goeggod"
-"ga" is inserted either side of the mid-point of any word of odd numbered length
 -puppy becomes "pugapgapy"
im unsure how i would go to adding the text to the string i  have got this so far
word= input("Please enter a word.")
length = len(word)
print(length)
if length % 2 == 0:
    length = length /2
    print(length)
    print("even")
else:
    print("Odd")
    length = length /2
    print(length)
this just finds out if its odd or even then i started to work out the mid point! im stuck can someone help please
Thanks
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/606607-python-help/
if len(word) % 2 == 0:
	return word[:len(word)/2] + egg + word[len(word)/2+1:]
else:
	#figure this out yourself :P
basically python strings are very nice to work with, and slicing them is super nice. read up on substrings ;)
Here is a nice summary of how slicing in python works, also has a link to the extensive documentation
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/606607-python-help/#findComment-7855765
else:
i have tried the code that you gave me and i dont want it in a function so i did it like this
    word = word[:len(word)/2] + egg + word[len(word)/2+1:]
    print("word")
else:
    print("odd")
but im getting the following error
TypeError: slice indices must be integers or None or have an __index__ method
even when i run your code and put it in a function?
}else{
https://linustechtips.com/topic/606607-python-help/#findComment-7855805
    print("word")
else:
    print("odd")
Try " + egg + word[(len(word)/2) + 1:]"
i dont remember how python does maths priority, but it may be trying to resolve that into len/3 which would result in a double, not an int
https://linustechtips.com/topic/606607-python-help/#findComment-7855819
i now have it like this
word[:len(word)/2] + egg + word[(len(word)/2) + 1:]
and it still throws that error
}else{
https://linustechtips.com/topic/606607-python-help/#findComment-7855830
ok now im cofused. try wrapping the slice indeces in the int() function or using the integer division //
https://linustechtips.com/topic/606607-python-help/#findComment-7855845
ive tried like this, but its invalid syntax
word = word int([:len(word)/2]) + egg + word int([(len(word)/2) + 1:])
as you can tell python is not my strong point.
}else{
https://linustechtips.com/topic/606607-python-help/#findComment-7855868
word[:int(len(word)/2)] would be the syntax
https://linustechtips.com/topic/606607-python-help/#findComment-7855911
This is my solution:
word = input("Please enter a word:")
length = len(word)
if length % 2 == 0:
	midpoint = length // 2
	output = word[:midpoint] + "egg" + word[midpoint:]
else:
	midpoint = int(length / 2 - 0.5)
	output = word[:midpoint] + "ga" + word[midpoint] + "ga" + word[midpoint+1:]
print(output)
https://linustechtips.com/topic/606607-python-help/#findComment-7855939
length = len(word)
if length % 2 == 0:
else:
print(output)
its not nice to just give out the whole solution, doesnt help him learn. but yes, that is how one would do that. a nice oneliner would be
return word[:len(word)//2 - 1] + "egg" + word[len(word)//2:] if len(word) % 2 == 0 else word[:len(word)//2] + "ga" + word[len(word)//2:len(word)//2 + 1] + "ga" + word[len(word)//2 + 1:]
https://linustechtips.com/topic/606607-python-help/#findComment-7855985
@jameshumphries47 your original code was good, you just forgot to enclose egg in quotes, as you want a string, not an object ;)
https://linustechtips.com/topic/606607-python-help/#findComment-7855991
