hi. my pc shows two different temps for my FX-4300. I guess CPU means the package. but i really doubt that the core is 7 degrees.  I also had this on a previous Athlon X2 220. why does it show so low temp for the core? When under load the core temp cgets around 30 degrees and the package 50 degrees
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/
What program are you using?
i like linux
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/#findComment-7847503
it's AIDA 64
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/#findComment-7847633
23 minutes ago, legonate416 said:
I would suggest looking at other programs such as SpeedFan, but generally the core temp is what you want to be worried about. I believe the CPU temp in general is the socket temp, though I'm not sure
that's what i want to know. my CPU has an TDP of 70 degrees max. and what I said earlyer under load. the CPU temp got 50 degrees while the core temp got 30 degrees max.  So i want to know where to look at. Also the ''core'' temp drops much quicker then the ''CPU''
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/#findComment-7847646
Yeah... Definitely try looking at Speedfan. AMD temps are finnicky with HWM in my experience
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/#findComment-7847653
this is what speedfan says
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/605744-cpu-temp-and-core-temp/#findComment-7847680
