So BL 2 was onsale today for $10 so I got it.... I can't get a framerate higher than 1fps on the main menu. resolution is 2560x1440. GPU GTX 780, CPU i7 4790K (no OC). NZXT CAM has my cpu under about 45% load with game running and GPU at around the same usage... help?
System: i7 4790K, Hyper 212 EVO, 16 GB Crucial Ballistix, GTX 1070 Super clocked, MSI Z97S SLI Krait Edition, Corsair RM 750, Corsair 750D (with 2 additional 140mm NZXT fans up top for exhaust.)
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/
BL2 runs like ass on anything after Fermi series NV GPU's.
let us all remember now and today, computers do not like abuse, they will fight back!
Old Skool KILLBOX. XEON E5640 4.0ghz / ASUS P6X58D-E ~ Noctua NH-L12 ~ eVGA GTX 670 SC 2GB 1312/7000 ~ 4TB 7200 RPM RAID0 ~ CoolerMaster Haf 922 ~ DELL P214H 23" 1080 IPS 2ms ~ HP w2007v 1680x1050. Now Playing: Splinter Cell OG XBOX / CSGO PC
Original XBOX - Xecuter 2 4981.67 Bios. Playstation 2 Slim SCPH-70002. Sega Dreamcast. N64
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845116
Have you tried verifying the game cache?
I'll leave this guide here so try it out. Worked for me aswell as other people.
I once explained to my girlfriend what true love is. I said, "If you were a shit, I'd put you back in" and to this day, she is still my little shit.
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845118
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845121
Thanks trying it now, side note before you replied I restarted my PC and managed to get to the menu with 30fps but when I would click something it would go back to the BL logo then back to the menu screen... rinse and repeat
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845124
Turn off vertical sync and check if your fps is capped, set it to uncapped if it isn't already and make sure vertical sync is off. BL 2 is notorious for being badly optimized so also try to bump it down to 1080P and see if that does anything for you. You should also check your drivers for your gpu try to mess around with physx, could be that you haven't updated your physx drivers aswell, so make sure you check all your gpu bound drivers.
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845144
about to do that, phsyx isn't available and is set to low by default.
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845147
The borderland franchise is the very gatekeeper to physx, it should be available, if its on low, just disable it.
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845156
UPDATE: used 1080p uncapped physx on low because I couldn't disable. Updated GPU drivers, results are still pretty much the same. EDIT The game also seems to do something with windows explorer making it almost completely un responsive. I can still pull up start menu but I can't type in the search bar (windows 10)
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845217
Another Update: tried reinstalling the game completely... issues are still there, also launching the game seems to cause issues with windows explorer, when I try to access the search feature I can't type anything and when I open file explorer it becomes unresponsive... I just wanna play Borderlands :(
https://linustechtips.com/topic/605536-bl-2-low-framerate-issue/#findComment-7845691
