Hi!
I get my new Strix R9 380 oc 4gb gpu. I installed Battlefield 4 and play for few minutes then gpu fans start and goes to full speed and it is very loud. Temperatures are about 65-68 celsius. Anybody have this gpu and have the same problem? I dont mind about loudness before but this fans are anoying.
https://linustechtips.com/topic/605246-r9-380-problem/
I'd take the loud noise to keep my parts cool and just put on some headphones.
You could change your fan profile to only run on max RPM's when it hits 80c.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/605246-r9-380-problem/#findComment-7842164
1 hour ago, TheRandomness said:
Not all the heatpipes in the cooler are making contact with the GPU. That's why people say to avoid Asus. You could setup a custom fan profile in MSI afterburner or something.
Totally wrong what you said. The heatpipes are touching each other and it makes the heat transfer better than only if the 2 or 1 heatpipe touching the would be used
https://linustechtips.com/topic/605246-r9-380-problem/#findComment-7842190
2 hours ago, vex_dm said:
I get message display driver stoped working. On cd driver version is 2.300 but on asus page newest driver is 2.200. Maybe there is a problem?
Don't use drivers from the cd. Use DDU to uninstall the drivers, and get the latest driver from AMD site
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/605246-r9-380-problem/#findComment-7845643
