Recently i decided to hide my pc in my closet to minimize  the noise and whining of fans but the suddenly my monitor would turn off mid game , sound would stutter a bi the sound would continue but without any picture this has happened countless times in the past week i have since then removed my pc from the closet but the problem persists i did monitor my gpu and cpu temps and all seemed to be fine i don't know what to do
https://linustechtips.com/topic/605187-please-help/
Do you have any overclocks? If so, remove them. If not, try underclocking the GPU core and RAM a bit.
Seems like a driver crash to me...
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/605187-please-help/#findComment-7841495
A graphics card has more overheating parts than just the GPU. The VRM and the VRAM don't even have sensors. Even if the GPU stays in check, it can be busted. But is that's the case, the problem would probably be reproducible by benchmarking software and it'd follow the hardware into a test setup. Try to find a reliable program to reproduce the problem and then ask a friend if you could try your card in their computer. Speaking of overheating, there's the PSU too.
https://linustechtips.com/topic/605187-please-help/#findComment-7841508
everything is running on stock clocks , and i have an aftermarket cooler on my cpu with the latest nvidea driver installed
https://linustechtips.com/topic/605187-please-help/#findComment-7841512
2 minutes ago, infern0_ said:
everything is sunning on stock clocks , and i have an aftermarket cooler on my cpu with the latest nvidea driver installed
Then please try underclocking the GPU. -50 on the core and -100 on the vRAM. It may / may not help, who knows...
https://linustechtips.com/topic/605187-please-help/#findComment-7841520
i havent see any issues from the card prior to putting my pc in the closet and i take very good care of my hardware , my power supply is  a 1275 watt thermal take plat and it has an overheating led which has never gone off
https://linustechtips.com/topic/605187-please-help/#findComment-7841525
could it be the nvidea driver i installed shortly after changing my cases position  ? i just hope i didnt ruin my hardware
https://linustechtips.com/topic/605187-please-help/#findComment-7841535
1 minute ago, infern0_ said:
i will do that now , and ill install an older version of the driver
Don't change 2 things at a time. Either underclock OR change the driver version; don't do both at the same time. Otherwise, diagnosing becomes much more difiicult.
https://linustechtips.com/topic/605187-please-help/#findComment-7841549
i underclocked for now , im gonna run gta 5 and see what happens it usually takes it about 30 min to an hour to crash , on  a side note i get that sound like a device was disconnected when the screen goes black
https://linustechtips.com/topic/605187-please-help/#findComment-7841566
First step should be looking at your windows event log and see what's happening...
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/605187-please-help/#findComment-7841571
Just report what's in the administrative events.
https://linustechtips.com/topic/605187-please-help/#findComment-7841595
here it is
You need to click "Administrative Events" and then look at the Warning/Error that are showing up around the time of a crash.
https://linustechtips.com/topic/605187-please-help/#findComment-7841629
The Net.Tcp Listener Adapter service depends on the Net.Tcp Port Sharing Service service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
ISCT - CAgentService::AgentServiceInit   NetDetect is now disabled since this is not a mobile platform
the 1st on is an error and the second is a warming
https://linustechtips.com/topic/605187-please-help/#findComment-7841633
There should be a bunch of errors. Normally you'll see something about video drivers or something.
https://linustechtips.com/topic/605187-please-help/#findComment-7841664
