edited
If your physically blocked (over a road or something)
There are directional antenas you can get to boost range.. Try some of these..
There are cheaper versions but this gives an idea of the directional antenna type solution.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/604129-wifi-range/#findComment-7829227
