psu help
Go to solution Solved by Smile,
Yes it will fit.
ABOUT ME: Hello, I'm a 15-year-old PC enthusiast. I love helping people with their problems and learning about the hardware of a PC.
DREAM JOBS: Computer Technician, I.T Consultant or a Computer Hardware Engineer.
NEXT BUILD: http://nz.pcpartpicker.com/list/rDXLJV (NOT COMPLETED)
BE NICE TO ONE ANOTHER AND HAVE SOME FUN!
https://linustechtips.com/topic/603991-psu-help/
Better for less though a bit low wattage. What are you running.. anything modern and intel//nvidia even mid range sli should be fine on the 650W Platinum
https://pcpartpicker.com/part/evga-power-supply-220p20650x1
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/603991-psu-help/#findComment-7827879
I was planning onto have a 980 Ti with a i7-6700k. will the PSU shown be good with that, and fit in my PC?
https://linustechtips.com/topic/603991-psu-help/#findComment-7830577
So that PSU i showed does not fit...
https://linustechtips.com/topic/603991-psu-help/#findComment-7837721
