Did you at least try moving the cable back? If that didn't work, try power cycling (unplug and re-plug) the modem and router.
Thy hath sinneth, and in thy life thou hast fallen to an unholy, unspeakable level of humanity. Thou hast given into your basest needs. And suffered many years under thine Satan-box. However, if thine be willing, as thy hast show yourself to be, thy can ascendeth into thy glorious fold of the glorious church. Go well, my brother, may your temps be low and your frames high. ~ MrDynamicMan
https://linustechtips.com/topic/603096-network-problem/#findComment-7819265
What does "switched a cable" mean? Did you replace it, or did you move where it is connected on the router? If you moved it, what port was it in before, and where did you move it to?
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/603096-network-problem/#findComment-7822521
