Hi. I just want to get this over with quick, so I'll be brief.
I build my PC and the motherboard is an MSI B150 PC MATE and it has a thing on the side called "EZ Debug LED" which I guess lights up if you have a problem with something.
So here's what happens when I turn on the PC:
CPU light comes on really quick, then
it turns off and DRAM lights up for about 3 seconds, then
VGA lights up for around the same time
Then all the lights turn off but when I turn off the PC, CPU flashes quickly before I guess the power cuts out.
I don't get signal to my TV connected via the motherboard's HDMI port.
I don't know what to dooooo. :( Feel free to ask questions to find out more if it's needed.
EDIT: Fans turn on. So I know there's power.
https://linustechtips.com/topic/603044-new-pc-ez-debug-led-lighting-up/
19 minutes ago, Julian2000nl said:
First unplug the power connectors and remove the memory and reinstall them.
Then reset CMOS (this is in the manual) then try one stick of memory at a time moving it to each slot then the other stick the same way. From their I would look for bent pins in the CPU socket on the motherboard.
Just google it yourself next time ;)
I didn't google it because I can't find anything. Also, I don't think the CPU is the problem because it only turns on really fast, then off again. Well, it stopped now that I have only one stick of RAM in there and I re-installed it... but the DRAM and VGA issues are still there... I tried re-connecting all the power cables and even took out the GPU and put it in again. Nothing.
Nevermind! It works now... I think. Thanks! :D
