Cooler installation help
Go to solution Solved by Jebonia,
Instructions are there for a reason ;) But from memory, I am pretty sure you have to remove the plastic thing on the mother board that the stock heatsink mounts onto. Then you procede to install the backplate and so on
Hi, i got all my parts yesterday and assembled the computer, but i cant figure out how to install my hyper 212 evo. I have a gigabyte fxa am3+ ud3 motherboard. Any help is appreciated
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/60253-cooler-installation-help/
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
https://linustechtips.com/topic/60253-cooler-installation-help/#findComment-818630
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/60253-cooler-installation-help/#findComment-818631
msi h77ma g43
i5 3470
Windows 8 64bit
Samsung dvd drive
LG IPS235p
Razer Blackwidow
Razer Deathadder
https://linustechtips.com/topic/60253-cooler-installation-help/#findComment-818642
yeah, it was the plastic things i was wondering about
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/60253-cooler-installation-help/#findComment-818692
