Hello,
I need help with this java database issue. The program can't seem to locate the driver. I got the driver and code I'm testing from this site: https://bitbucket.org/xerial/sqlite-jdbc The only difference with class name but everything else is the same. I attached a picture of the problem.
Error:
Exception in thread "main" java.lang.Error: Unresolved compilation problem:
    at dbtest.DBTest.main(DBTest.java:9)
Line 9 is the highlighted code in the attached screenshot.
My system: CPU: Intel i5 6500; Mobo: H110M-k; GPU: Nvidia GT 730; Memory: 16 GB; HDD: 2x 1TB HDD;
https://linustechtips.com/topic/601951-java-sqlite-driver-issue/
11 hours ago, vibeit said:
Hello,
Error:
dont do an executeUpdate, do a straight execute. also, it should probably be "insert into person(id,name) values (1, 'leo')" same for the next line
https://linustechtips.com/topic/601951-java-sqlite-driver-issue/#findComment-7810544
