2 minutes ago, SlienceRain said:
Hey.guys
I have a question,
I have a AMD X4 860K as my cpu, and its oc to 4.30GHZ but for some reason it doesn't us all the speed it only use 4.21Ghz.
I'm not sure why is that happening, also my PC self restarts sometimes, its bugging me a lot.
Sounds to me like you're pushing it too hard. Maybe back down on the OC?
Screenaninator: Sapphire Radeon R9 390 Nitro
Procrastinator: AMD FX-8300
Stickaminator: 16GB Crucial Vengance DDR3
Powermathingy: Corsair RM850i
attachamajiggy: Asus M5A97 R2.0 f
Remembrerthing: 240 GB Crucial SSD, 2TB Toshiba HDD
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807397
1 minute ago, SlienceRain said:
and the base clock is 3.70Ghz
Obviously it's having trouble pushing 4.2Ghz or above. Why not set it to 4.1Ghz, and see how that does for you? I can assure you that, in this day and age, 100Mhz difference on your CPU is going to make NO noticeable difference in performance. Slow it down, and it will run more stable.
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807410
cool i'll have a try
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807411
and do you know why is my PC keep self restarting once awhile
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807414
Yes, because you're pushing the CPU past what it can handle, and it is causing it to have fatal errors. When you're overclocking, if your computer locks up, that means you're pushing it too hard, and you need to back it off. Back it down to 4.1Ghz as I said, then run a stability test on it. If it passes the test, you're golden. If it doesn't, then push it down to 4.0Ghz.
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807422
cool thanks
https://linustechtips.com/topic/601938-cpu-problem/#findComment-7807426
