best GPU you can get for around $200:  GTX 970 (used) but I recommend waiting a bit longer before buying so that the most 970 user who want to upgrade to a 1070 will post on there...  current lowest is $230 for US. (buy it now)
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/601888-best-for-200/#findComment-7806966
used 780
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/601888-best-for-200/#findComment-7806969
I tend to avoid Radeon cards, (not due to fanboy issues. Just had bad experiences with them in the past) so I can't really give any advice for that.
You could easily get a 2GB 960 for under $200 USD. Possibly even a 4GB 960 if you keep an eye out for sales / discount codes.
If you're willing to shop used / refurbished. With some shopping around, you could probably get up to a 970 for under $200.
https://linustechtips.com/topic/601888-best-for-200/#findComment-7806973
12 minutes ago, realaton said:
whats the best gpu you can get for $200
R9 380 4GB - 15% faster than the 960 in DX11 and over 30% faster in DX12
https://linustechtips.com/topic/601888-best-for-200/#findComment-7806988
R9 380X 4gb PCS+ is $180 after rebates, $200 without. its the best you can get for $200.
https://linustechtips.com/topic/601888-best-for-200/#findComment-7807126
the r9 380 m4
https://linustechtips.com/topic/601888-best-for-200/#findComment-7812112
R9 380
even better, a used 780 or 290
https://linustechtips.com/topic/601888-best-for-200/#findComment-7812129
  • 2 months later...
