Hey LTT,
   So I've been experimenting with Python for a while, and (with the aid of a tutorial) have made a keylogger just to practice. I followed the tutorial perfectly, and I understand most of the code from my own experience, but I'm having trouble with one part. Whenever I log my keytaps, they come out as weird encoded symbols. I'm on Python 3.5.1. Code is below. Thanks for any help you can give!
def OnKeyboardEvent(event):
    logging.basicConfig(filename=file_log, level=logging.DEBUG, format='%(message)s')
    event.Ascii
    logging.log(10, chr(event.Ascii))
    return True
Thanks,
MDPS
  Christian
Use the following style specs in your sig to spread the LTT revolution!
Rig Specs:
Screeninator: Gigabyte GeForce GTX960
Powermathingy: Corsair CX600W
Stickiminator: 2x G.Skill ARES 4GB DDR3-1866
Procrastinator: AMD FX-8350 @4.1GHz 1.3V
Holdametalicizor: DIYPC Gamemax-BK
Noisoundacreator: Cyber Acoustics CA-3072 (loudamagargle) Onn Wireless FM Radio Headset (earamagargle)
Attachamathingy: ASRock 990FX Extreme9
Remembrerthing: Western Digital 1TB Blue, Western Digital 40GB Blue
Flat-Colorful-Thing: Acer K272HL
See-A-Move-O: Logitech Hyperion Fury G402
ButtonBoard: Cooler Master CMSTORM Devastator Blue
Talkamagargle: Blue Snowball Ice
https://linustechtips.com/topic/601788-need-help-with-python-code/
7 hours ago, Gachr said:
Could you please give a working example?
It's probably just because computers read keys with their number, not the character, so they can use different keymaps.
What do you mean a working example? I could give you the script or a screenshot of the characters if you'd like.
EDIT: attached screenshot.
  Christian
Rig Specs:
1 minute ago, fizzlesticks said:
That would help.
Attached as a .pyw
KeyLogger.pyw
  Christian
Rig Specs:
23 minutes ago, fizzlesticks said:
It seems to be working fine for me.
Do you use a standard qwerty keyboard?
Yes. For me it keeps loading characters as pictured above.
  Christian
Rig Specs:
