Need Help With Python Wheels
Go to solution Solved by fizzlesticks,
1 minute ago, MDPS said:
Using the pip command in CMD. the .whl is in the downloads
Inside the CMD you have to either navigate to your downloads folder or put the full path of the file.
Hey LTT,
   So I've been trying for awhile to install pyHook-1.5.1-cp35-none-win_amd64.whl using pip but so far it hasn't been going well. Whenever I try to install it using:
pip install pyHook-1.5.1-cp35-none-win_amd64.whl
it says (first of all) that it does not exist, and then lays out a bunch of exception errors. I have Python 3.5.1 64-Bit and latest version of pip. I also left the .whl in the downloads folder after getting it. Any help is much appreciated!
Thanks,
MDPS
  Christian
Use the following style specs in your sig to spread the LTT revolution!
Rig Specs:
Screeninator: Gigabyte GeForce GTX960
Powermathingy: Corsair CX600W
Stickiminator: 2x G.Skill ARES 4GB DDR3-1866
Procrastinator: AMD FX-8350 @4.1GHz 1.3V
Holdametalicizor: DIYPC Gamemax-BK
Noisoundacreator: Cyber Acoustics CA-3072 (loudamagargle) Onn Wireless FM Radio Headset (earamagargle)
Attachamathingy: ASRock 990FX Extreme9
Remembrerthing: Western Digital 1TB Blue, Western Digital 40GB Blue
Flat-Colorful-Thing: Acer K272HL
See-A-Move-O: Logitech Hyperion Fury G402
ButtonBoard: Cooler Master CMSTORM Devastator Blue
Talkamagargle: Blue Snowball Ice
https://linustechtips.com/topic/601750-need-help-with-python-wheels/
2 minutes ago, fizzlesticks said:
Are you using the pip command from inside the same folder the .whl is in?
Copy and paste the exact error.
Requirement 'pyHook-1.5.1-cp35-none-win_amd64.whl' looks like a filename, but the file does not exist
Is the error, followed by the exception errors.
  Christian
Rig Specs:
Okay thanks a lot! I'll try that. Never used wheels before so I have no clue how to install them lol.
  Christian
Rig Specs:
Okay I got it! Thanks a lot for the help. Quick question though, once I've installed the wheel, can I delete the file?
  Christian
Rig Specs:
12 minutes ago, fizzlesticks said:
Yes.
Thanks a lot for everything!
  Christian
Rig Specs:
