Blower vs non-blower cooling
Go to solution Solved by Vitalius,
Your room temperature would not change at all, if it would it will be minute.
This^
Basically, non-Blower fans are best for single GPU solutions because there is plenty of space, and thereby, air, to pull in to use to cool the card.
Blower fans are better for Multi-GPU solutions because there is less air to get and blowers are better in tight spaces for cooling. It is especially important to get the hot air out of the case since there are multiple GPU's and you do not want the GPU's fans recycling the air again and again.
So comparing blower to non blowers, which would likely keep one's room temp lower?  I mean I one hand you have non blowers exhausting into the case likely making other components hit higher temps(even if only slightly).  But on the other hand you have blowers exhausting possibly higher temps into the room.  Or is this just plain moot and will barely affect the temperature of one's room(more likely I'm guessing)?  I'm curious because while I've always gone aftermarket on cpu cooling and always been about trying to keep my PC cool, I feel these days even more so I care about my room's temperature(want to be comfy you know).
https://linustechtips.com/topic/60134-blower-vs-non-blower-cooling/
This^
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
Non blowers: Blowing air inside the case before it eventually seeps out through crack into your room.
Blower: Blowing air out of your case casing your room to heat up faster but no more since all the heat will eventually come into the room anyway...
Non blower fans cool the GPU better while blower fans doesn´t heat the other components :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
Ohh and since you are relatively new with only 7 posts...
Welcome to the LTT forum! :D The only forum on the Internet where you get 5 answer within 5 minutes explaining your question :)
Edit: You have been here longer then me sooo...
Edited by Titanicium
Tor
Thanks for the welcome, and answers.  I kind of figured it wouldn't really do anything for my room, but still nice to learn a few things like blowers being better for multi gpu configs.  Haven't posted here much as I'm a member of a few forums(different topics though) so between them and all the other things on the internets I haven't quite looked around here much(though I did a pinch of keyboard research/lurking here).
Edit: Question was inspired by Linus' unboxing of the Manli GTX770(for the curious).
Of course you can always be a BOSS and water cool, then it doesn't matter what kind of air cooler the card has...  :D
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
whoa, whoa partner.. that statement is loaded with all kinds of false statements.
it does matter what cooler/card is for water cooling. not all GPU PCBs are the same
in a GPU series. depends on the partner manufacturing the card what PCB is used.
they are not all the same and the air cooler can sometimes denote that effort. it is
best to consult a water block manufacturer for proper details on block availability.
come hangout in the water cooling section with "oops i bought the wrong card stories".
airdeano
^Yeap there's such a thing called reference PCBs and non-reference PCBs
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
Lol, was just joking.  I meant it doesn't matter whether the reference cooler is a blower type or not...
