1 minute ago, Number said:
As far as I know, Kinguin only sells the keys. Are you sure you got the .iso file from Kinguin?
ah well from underneath,
1. Download the installation package from this website
2. Create an image following the instructions from here
3. Install your new Operating System
4. If needed download the language pack from here and install it on your PC.
https://linustechtips.com/topic/601274-rufus-iso-problem/#findComment-7800180
