Hello guys,
          Sometimes if I leave a skype call or call back repeatedly, my audio will cut out. Videos will not play, and music will not work. I'd like to know why. Sometimes it happens randomly, but not very frequently luckily.All help is appreciated, thank you in advance.
Here is my build: http://pcpartpicker.com/user/Hydrogen1803/saved/pK7bt6
https://linustechtips.com/topic/601255-audio-glitch/
Sometimes my audio switches from rear panel audio to front panel audio for no reason. I think it is worth to check out your audio manager to see which audio port your audio is being output on.
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/601255-audio-glitch/#findComment-7800016
I'll do this, and see if I find anything, thank you.
https://linustechtips.com/topic/601255-audio-glitch/#findComment-7800022
Also, I don't know if it matters, but I have my headphones coming out of an M-Audio Fast Track, and my mic on an extension aux cord.
https://linustechtips.com/topic/601255-audio-glitch/#findComment-7800024
You output through usb? I'm not really sure then. I've never had experience with USB output.
https://linustechtips.com/topic/601255-audio-glitch/#findComment-7800036
Okay, I'm starting to wonder, possibly it could be because of the device's software. That got me thinking. I'll look in to it, thank you again.
https://linustechtips.com/topic/601255-audio-glitch/#findComment-7800039
