Well it can change the size of the card and how much space you will need
Some will bigger some will be smaller. When the different vendors release the specs check the card lengths but I doubt they'll have released them yet
The Reference card is about 27cm long (10.5")
https://linustechtips.com/topic/601157-case-size-help/#findComment-7799173
