Don't buy a 980ti but a 1080 instead.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798056
If I were you, I'd just get 1 stick of 8gb RAM for now. This is so that, if for some reason later on, you can add another 8gb if need be. Since the motherboard only has two dimm slots, I think this is the way to go. :)
~~ Intel Xeon E5-2696 v4, Asus X99-A II, Adata 2x8 GB, EVGA GTX 980Ti FTW, InWin 303, Dell U3415W~~
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798057
3 minutes ago, y_unit265 said:
I am currently under the impression that the boardpartners are going to reveal their own designs at computex.
Ah ok thank you very much. I've just seen that the founders edition is available to pre-order for £619 here, so I guess the standard edition would be around £549 which is practically the same as the MSI GTX980ti
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798095
I believe that the pre-order cards have a price premium on them. As far as I am aware, they cost more then when you start ordering them after they have been released and will be selling for the prices Nvidia dropped. (Welcome to marketing -.-')
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798107
But then again, you could get a used 980ti for much cheaper now. I've seen them go for around 350-400 USD on eBay. that would be roughly  £270-300
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798111
Do not get the founders edition.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798151
16 minutes ago, y_unit265 said:
It looks fine. You can drop the clockspeed on the ram as your processor only supports DDR4-1866/2133, DDR3L-1333/1600.  But as everyone has been saying, wait until the GTX 1070/1080 are released and look for either a 1070/1080 or a cheaper 980ti ;)
The cpu might only support that speed according to Intel, but you can use much faster DDR4 ram if you want on that MSI board.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798161
4 minutes ago, Matias_Chambers said:
http://uk.pcpartpicker.com/p/BbyKHN You forgot a PSU, I switched out the GPU for a 1080. I'm not sure if 400 pounds will be the price in Britain I just used a currency converter.
Well spotted, I didn't actually forget I just couldn't find the link + forgot to post it here.
I actually have the 750W version of that PSU on my amazon wishlist, but perhaps that might be a bit overkill.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798188
It is overkill.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798189
Not a chance that the GTX 1080 will be £400. I think £600+ is more realistic.
PSU is overpriced as well. You can get the EVGA G2 550W for £70.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798192
It'll just downclock the ram. By this you'll just spend extra money on something that doesn't add anything. It is basically the same as saying that a 1600W psu can power a 600W system. You don't gain that much (if anything) from doing so.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798198
Yeah, I just used a currency converter. And yeah you could go with a cheaper PSU, the G2 is a very good choice.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798201
No it won't downclock the ram. The xmp profile will run it at the correct speed.
https://linustechtips.com/topic/601088-first-pc-build/#findComment-7798211
