5 minutes ago, Danish_PSU said:
Can someone link me some bright LEDS? I'm trying to put some behind my desk, monitor and inside, and under my PC, About 150"
They need to be bright, and cuttable, also please link me the necessary things i'll need to cut and reconnect the strips, thanks!
You can get RGB LED kits online say at Amazon or Ebay as long as you don't mind doing a bit of work wiring up the LED's themselves but it should be quite straight forward.
http://www.amazon.com/SUPERNIGHT-Waterproof-300LEDs-Flexible-Controller/dp/B00B2F3KDQ?ie=UTF8
-Moved to Modding Section-
https://linustechtips.com/topic/600892-rgb-led-strips/#findComment-7796257
Are they pretty bright? because i've seen some that are almost invisible like linus' in this video lol
https://linustechtips.com/topic/600892-rgb-led-strips/#findComment-7796272
It's just in video, they are the standard SMD5050 LED's which are quite bright, I would recommend setting them up so you have no visible line of sight to the LED's but have it cast light out or bounce off the wall to give it that glowing backlight effect.
https://linustechtips.com/topic/600892-rgb-led-strips/#findComment-7796301
CABLEMOD WIDEBEAM LED MAGNETIC RGB.
These are definitely the best RGB strips you can buy.
Plus, if you have an Asus board with an Aura connector, you can manage your LED's through software, and set up programs and lighting effects.
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/600892-rgb-led-strips/#findComment-7796333
