Hey guys! so I did not post pictures of my previous rig because well quite honestly I was way too embarrassed too, however now I have, what I think is a clean build, to show off. I hope you like it and I'm always open to criticism.
Here are the internal and externals.
Externals:
Case: NZXT H440 black on black.
Monitor: Some random Dell 1080p monitor i picked up from a restoration company for free.
Keyboard/Mouse: Razer Deathstalker Chroma and a Deathadder Chroma
Headset: Lenovo Y Gaming Surround Sound Headset
Internals: AMD Platform
Mobo: MSI 970 Gaming.
CPU: FX6300 6-core 3.5 turbo 4.1 GHz (plans are in the making for replacing)
Cooler: Cooler Master Hyper 212 EVO
RAM: EVGA 16GB (8BGx2) 2300MHz
GPU: MSI R9 390 8GB
Fans: 3X Thermaltake riing 140mm, 2 top, 1 back. 3X NZXT 120mm in the front. 1X stock 120mm Cooler Master fan.
Storage: Intel SSD 250GB, WD 1TB 7200RPM
PSU: Corsair 750W 80+ Bronze Certified.
https://linustechtips.com/topic/600349-my-first-clean-build/
I quite like how the 970 gaming looks :)
Although for aesthetics' sake I'd turn the EVO 90 degrees so that we can get a look at those sexy Black and Red VRM heatsinks.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790175
Externals:
GPU: MSI R9 390 8GB
A 6300 with a 390 and a CX750?
Build looks nice though.
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790211
Turn the 212 90 degrees. Looks better that way.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790214
It was optimal at the time for the case that it was in. I was thinking about doing just that though. Thanks!
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790218
Well thats what I was told to get from someone who works at microcenter. I have an 8320 replacement planned. lol
Not going to be much better.
1 hour ago, Murican said:
Replace it with an 8350. IT's much faster.
You mean the 8320 clocked higher?
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790231
The CXs can only operate at up to 30 degrees ambient. So if the heat gets cranked up (like in a closed case) or if airflow is restricted it will shut itself off under load.
I've seen more than one topic here in LTT where someone would be gaming and their computer shut down out of the blue, no BSOD no nothing. And in many cases the culprit was a CX series power supply.
Computer Specs:
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790282
well, I will total call myself a dumb dumb haha. i was on a tight budget and acted to hastily. luckily i can still return the 750. and im going for a 1000. should be good then haha
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790318
Get exactly this power supply.
http://www.microcenter.com/product/460288/CX650M_650_Watt_ATX_Modular_Power_Supply
Now these are also called CX, but they're based on a new platform that can work at up to 40 degrees ambient temperature (that's 104F, quite the hot environment) and perform very well in general.
You can tell they're the new CX because they have a grey sticker.
You can get this one alternatively.
http://www.microcenter.com/product/457200/CP-9020054_RM_Series_650_Watt_Power_Supply_Refurbished
Computer Specs:
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790333
1 minute ago, Ghost0625 said:
watt
Yeah no, your build doesn't need that. Just get a quality 500 watt PSU.
You can do better than that easily. Like this:
http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm
Or this:
http://pcpartpicker.com/part/evga-power-supply-210gq0750
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790337
Just now, Ghost0625 said:
wait. i thought 750 was not going to be enough.
Actually your system will pull about 420-450 under load :)
It's just that the CX750 will get too hot and throw a temper(ature) tantrum. :P
Computer Specs:
https://linustechtips.com/topic/600349-my-first-clean-build/#findComment-7790351
