Hello building my PC and now i am installing X61 Kraken, but backplate doesnt want to fit on its place..... on the back of H440[Red] there is thing that blocks left down end of the backplate.
HELP!
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/599717-kraken-x61-backplate-problem/
Screw in the other mounting holes and then push it and screw, it will be on strong enough to negate the extra disatance.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
You sure, becuase if i push it can break or something :/ When i unscrew them
Project Redline:
I meant on the X61! Not the motherboard, Screw the X61 Pump in on the three remaining standoff / screws, then push the last one closer to the board and cooler, then screw it in.
But i cant push other 3 in place 4rd one holds me.... if i push stronger 4rd will break...
Project Redline:
4 minutes ago, Redjo said:
But i cant push other 3 in place 4 holds me.... if i push stronger 4rd will break...
You are going to have to  cut out the rest of the case that is stopping it. Or alternatively remove the board and mount it there.
HMMMMMMMMM fuck!
Why do i even have this problem, it was suppose to be OK! :/
Fuck man!
Project Redline:
1 minute ago, Redjo said:
HMMMMMMMMM fuck!
Fuck man!
Just remove the board and mount, it should be fine.
Ya seems like thats the only way....
I am amateur and scared to not break something tho....  and now have to unmount it and mount it again...
Project Redline:
