Hi Guys,
I've been scratching my head and searching around how to fix a GPU cooling issue I have.
Rig:
6700k (Corsair H115i)
Asus Maximus VIII Impact
NZXT Manta
Windows 10 Home
I just installed a Corsair HG10 N980 on my 980ti being cooled by a Corsair H105 AIO in P/P. The issue is that I have all 4 fans on the H105 on the fan hub on the case that is plugged into a PWM header on my mobo and what I want to achieve is to have the 4 H105 fans to ramp up as GPU temps go up, probably going to have to be via some software (hopefully).
I have tried Speedfan (+ latest beta) but it has no support for my mobo or cant figure out how to get it work for me (beta).
If I can't find a solution via software then my back up plan is to get a mini 4 pin GPU PWM Y cable (from ModDIY), taking everything apart (nightmare) and run it to the fan hub controller and do it that way.
Any knowledge would be very much appreciated!
Thank you in advance
https://linustechtips.com/topic/599362-gpu-aio-rad-fan-control/
4 hours ago, Dean.M said:
-SNIP-
Unless you have an Asus branded GPU the motherboard's built in fan control or software package AI suite will not allow fan control to the GPU unfortunately. If your motherboard has an option to add in a temp probe the only thing I can think of is to have it placed in the GPU's AIO rad and have the fan control based off that temp probe.
https://linustechtips.com/topic/599362-gpu-aio-rad-fan-control/#findComment-7780954
Switch the cpu cooler fans to the board as they can be controlled via the board software. Plug the gpu fans into the cpu cooler with can control the fans based of gpu temp via corsair link. That's what I did anyway.
https://linustechtips.com/topic/599362-gpu-aio-rad-fan-control/#findComment-7781153
