Need help
Solved by Guest,
5 minutes ago, GrimReapez said:I currently want to buy a MSI Z87-GD65 GAMING Motherboard , but i dont know if its a Atx mobo , and i also want to know if it supports the i5 4590 or work with a msi r9 390 Gpu , and if it will fit in the
RAIDMAX Horus ATX-322WB
Can someone tell me please? cause my other motherboard which is a Micro Atx is too small.
1. Its an ATX mobo.
2. It does support the i5 4590 but may require a BIOS update to do so.
3. Yes it will work with an MSI R9 390
4. Lenght wise, yes but height wise im not sure.
