So I just moved from one room on the second floor to a room on our attic and connected my PC as usual with my dlan adapter from devolo. First it didn't even connect, but after a few tries it finally worked. But extremely slow.... Normally I have a download rate of 2.1 mb/s, now I can't even open a speed test site to know how fast I'm downloading. In team speak everyone can understand me without a my lag, but I can't hear any word from ten because it lags so much. I don't seem to find a solution on my own, somebody know what to do?
https://linustechtips.com/topic/599200-dlan-connection-extremly-slow/
It sounds to me like you're on a different circuit now and are probably being slowed down as a result. A lot of times those types of adapters don't perform very well when you end up trying to send data through your breaker box. I don't have a whole lot of experience with them but I do know when I tried having the adapters on separate circuits I saw a huge performance drop.
The best thing to do would be to try to identify if there are any outlets in the two areas that are on the same circuit and try to move the adapters to use those.
How can I see if two outlets are in the same circuit? I don't know much of this
Easiest way would be to flip the breaker off to the room your connection originates in, usually labeled in your breaker box and then take a lamp and go around plugging into outlets to see which all ones are dead. Try to make sure that both of your adapters are on outlets that are off at the same time with your breaker off.
Power line networking can be pretty finicky though so you might be better off moving to a wireless solution if you can't find something on the same circuit to use.
Disclaimer: please use caution when dealing with electricity.
Well I can say for certain that my old outlet wasn't in the same circuit as my router, because once the whole second floor was shut down, but the router still functioned, my whole room and outlets didn't.
And wouldn't it affect both upload and download speed? Because my upload speed seems to be as usual
I would think that you'd see a performance hit on both but typically DSL upload speeds are a lot slower than the download speed you get so it may be less noticeable because by design the upload is already much slower so it may simply not be a bottle neck or anything but your download.
My upload speed is a lot faster than my download speed right now, that is the problem... And I need Internet for a presentation, it's a bit hard to do it with my phone.
Hmm, ok and if you don't have something like DSL or cable the uploads and downloads could be rated the same. From what I can see on the forums related to the specific brand of adapter you have it can be related to the physical connections of power line on the wall outlet, I'd try a couple different outlets even if they are on different circuits and see if that makes any difference. Something minor like a slightly bad connection can cause issues with these because they're so sensitive. Something you'd never even know about when just using the outlet for power.
I tried some others out, but only one works with super slow speed, the others don't even have a connection... And I ran out of outlets to use
At this point there probably isn't a whole lot you can do to fix it besides moving the adapter to the same circuit as the other. This is, unfortunately, an illustration of why power line networking hasn't gained a whole lot of traction and never really took off as a solution.
    Yeah I see now that it probably was a mistake to switch to dlan
