 have an Asus Maximus VIII Gene MB, and in my build I am using the Alphacool LCD display panel that I customized to show system information. I cant get the CPU temp because the MBM5 application does not work, neither can i get Asus Probe II to install and work. I know many my suggest Aida64 instead of the Alphacool native application, but there are special features that the native application provides that Aida64 do not. If anyone has ever used this panel or similar I am asking for your help in figuring this problem out.
-With the MBM5 application. It kept saying "driver not loaded" I Google and no one has a solution for it.
-The Asus Probe II just does not work, the application dont even open.
-The other option was RiveTuner, but I cant find a version that works properly, because i cant find the preference option that enables "Hardware Monitoring"
https://linustechtips.com/topic/598597-help-needed-with-alphacool-lcd-display/
