Molex Case Fan to Motherboard?
Solved by Naeaes,
That adapter is your only choice. But it doesn't have the third pin that's required for speed reporting. Worst case scenario would be that you still won't be able to control the speed. If I were you, I'd get new fans. Or re-wire the ones you have to make them run slower.
Featured Topics
xKempo ·
Posted in Troubleshooting0 -
1
Dcorrigan97 ·
Davidf4e ·
Posted in Troubleshooting1 -
3
2
3
Bobzcpu ·
Posted in Power Supplies2 -
2
RZBAKA ·
Posted in New Builds and Planning8
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
