I have been having a problem with windows 10 audio. It kept changing up and down when a louder or quieter piece of the music was playing and I only just found the solution. This is for people that may have been having the same problem.
You need to right click on the volume bar and go to playback devices. Right click on the default audio device you are using. Go to properties > Advanced > Enhancements. Then click on disable all enhancements and you will be able to choose the volume yourself rather than windows trying to regulate this.
Hope this helps :)
https://linustechtips.com/topic/597839-windows-10-audio-changing-problem/
Hope this helps :)
This will definitely help. I've seen this happen a number of times
Just waiting for that next upgrade
Current Build:
CPU: Intel i5-3750
Motherboard: Asus P8Z77-V LK
Ram: 16GB Corsair Vengance
GPU: EVGA GTX 660 FTW
Case: Thermaltake Chase MK-1
Storage: Intel 480GB 535 Series SSD, Seagate 1TB
PSU: Corsair TX750M
Other Systems:
Dell Poweredge 840/2800 A.K.A Frankenedge or Frank for short
Coming Soon....
