Okay so this is probably really stupid but i cant seem to figure out what is going on. Basically i used a 128gig flash drive to do a fresh install of windows on. After i did the install its only showing up at 32 gigs as usable. Everywhere i read it tells me to right click the black unallocated to format it etc, but every option is greyed out.
Does anybody know how to get the 83.12 gb back without having to buy a new flashdrive?
https://linustechtips.com/topic/597586-disk-management-issues/
Try reformatting from Windows explorer.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760518
try right clicking the blue part and see if you can extend the volume. otherwise, try formatting in something else like exFat
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760522
Just now, skatblast said:
It only lets me chose up to 32gigs
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760531
Yeah it is greyed out and wont let me extend it. It is just weird because this is the second flash drive that this has happened to after using the windows 10 tool to create a bootable drive to install the OS on. Im assuming its 32gb because it formats it in fat32 format and that is the cap... but why would it not let me extend it back in NTFS after im done?
Just really strange because this seem to be some kind of issue but i have never heard about it from anybody else
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760563
Where did you buy the flash drive from?
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760613
5 minutes ago, skatblast said:
Might initial thoughts were that it could be a fake 128 GB.  Fakes show up as whatever they claim it to be, but the only usable space is that of the actual drive size of say, 16 or 32 GB.
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760640
Just now, done12many2 said:
Might initial thoughts were that's it could be a fake 128 GB.  Fakes show up as whatever they claim it to be, but the only usable stave is that of the actual drive size of say, 16 or 32 GB.
Nah, i had the drive for a few months and the 128gb worked fine it just did this after i used the windows 10 tool
https://linustechtips.com/topic/597586-disk-management-issues/#findComment-7760644
