I have an ssd and a mechanical drive in my system and each drive has a system reserved partition on it. Which one is used for the OS? I have attached a picture
Just waiting for that next upgrade
Current Build:
CPU: Intel i5-3750
Motherboard: Asus P8Z77-V LK
Ram: 16GB Corsair Vengance
GPU: EVGA GTX 660 FTW
Case: Thermaltake Chase MK-1
Storage: Intel 480GB 535 Series SSD, Seagate 1TB
PSU: Corsair TX750M
Other Systems:
Dell Poweredge 840/2800 A.K.A Frankenedge or Frank for short
Coming Soon....
https://linustechtips.com/topic/597561-two-system-reserved-partitions/
'Primary'.
You can tell by the Boot and Page File if you haven't done anything crazy with your OS. Also by the fact that it's primary unless you named it otherwise.
Usually C: is going to be your main if it's listed and you're not purposefully booting off of something else.
CPU i5 4670k
 Motherboard MSI Z87 MPOWER
RAM DDR3, 16GB
GPU XFX R9 390x
Case Raidmax Vampire (Soon to be MasterCase Pro 5)
Storage WD10EZEX-00KUWA0
PSU EVGA 220-G2-0750-XR 80 PLUS GOLD 750W
Display(s) LG 29UM67 (Ultrawide 29in)
Keyboard HAVIT HV-KB380L
Mouse Redragon Perdition
Sound Extremely old, deliciously sexy Harman Kardons
Operating System W10, VMs of El Capitan, W7, WXP, and Unix
1 minute ago, Cralineleader said:
'Primary'.
So I could delete the reserved and recovery partitions on my secondary (non ssd drive)?
Current Build:
CPU: Intel i5-3750
PSU: Corsair TX750M
Other Systems:
Coming Soon....
If you want to be sure, check everything on the secondary. If you see a Programs Files or Program Files (x64) folder, don't touch it anyway.
Otherwise, should be good to go.
CPU i5 4670k
RAM DDR3, 16GB
GPU XFX R9 390x
yea the only files on that drive is my steam library so i should be all good?
Current Build:
CPU: Intel i5-3750
PSU: Corsair TX750M
Other Systems:
Coming Soon....
Yep, you'd be perfectly fine. You just won't have your steam library lol.
If you ever wonder, check the contents. As long as you don't see those program files folders on your Windows machine, it's safe to delete the partition.
CPU i5 4670k
RAM DDR3, 16GB
GPU XFX R9 390x
I dont want to delete my steam library just the extra partitions. will deleting the reserved and recovery partitions delete the steam library if i dont delete the main partition for that drive?
Current Build:
CPU: Intel i5-3750
PSU: Corsair TX750M
Other Systems:
Coming Soon....
Nope. What you see in that partition is what you have in it. Those other partitions can be made visible by assigning them a letter.
You'll be fine deleting them.
CPU i5 4670k
RAM DDR3, 16GB
GPU XFX R9 390x
It almost looks like that data drive was formatted as a system disk for some reason, so I'm going to +1 in favor for deletion. Reclaiming the space if you want it might require another tool. I've never really had much luck using Windows' built-in partition manager in getting exactly what I want.
11 hours ago, Sir_Awesome said:
~snip~
Hey there :) (I love the avatar!),
The easiest way would be to remove one of the drives and see if the system boots with the other. This way you can see if that particular drive holds your OS (unless you have another one installed on the other drive). If the system boots properly, you should be able to delete any partitions, files and folders from the other drive without damaging the OS.
How did you end up with these partitions? Are you reusing one of those drives? Did you perform a clone procedure?
Post back with some more info so we can give you some guidance if needed. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
Captain_WD.
yea a while back when i bought the ssd I cloned it off of this drive. I deleted the partitions on that drive and it was all good, booted just fine. Like you said probably partitions left over from the clone process
Current Build:
CPU: Intel i5-3750
PSU: Corsair TX750M
Other Systems:
Coming Soon....
16 hours ago, Sir_Awesome said:
~snip~
In this case you should be safe to delete the old system partitions from the old drive. :) Post back if you have problems or other issues. Also, don't forget to create a backup before doing so in case something goes sideways.
Captain_WD.
