Mx Master Problems
Solved by MimigaKing,
last option, if possible. did you try it on another computer?
Otherwise, might have to got the RMA route.
As a reference, I've had mine since August, it flown with me across the world and is still working perfectly, albeit it lost some color on the left click button ![]()
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
