Good day/evening,
So i'm gonna build my computer and i've been switching through cases that i wanted to build in. Finally coming to an conclusion, going for the Zalman Z9 Neo. However i'm planning on getting some "Corsair Air Series SP120 High Static Pressure (Red LED, 120 mm)" and placing those in the case instead of the pre-installed blue led fans that come with the case, but the front IO still has the blue led when the power button is pushed and the usb ports still shine blue aswell, so here's my question: "Can you switch the blue LED's/lights in the front IO for red ones? And if so, how?"
Thank you for taking your time reading and/or responding in advance.
-Damian v. D.
https://linustechtips.com/topic/597282-changing-front-io-lights/
You can replace the switch entirely with a blue led one (eg. http://www.frozencpu.com/cat/l2/g44/c153/list/p1/DIYMod_Parts-Switches.html, make sure its momentary)
For the USB ports it would be a bigger job but you could do the same and replace them, or you could cut the wire for the LED and have them not glow at all.
https://linustechtips.com/topic/597282-changing-front-io-lights/#findComment-7756904
11 hours ago, DmnGameFreak said:
-SNIP-
It's not overly difficult as long as you can access the LED, most times it's just a simple 3mm or 5mm LED diode which can be cut off and a new one soldered into place.
https://linustechtips.com/topic/597282-changing-front-io-lights/#findComment-7760473
