I had too reinstall windows since i first installed pro but after i while i discovered that to me it was definetly not worth twice the prize, but now that have deleted everyting on the computer and made a usb stick boot device. i put it and nbothing happens i try many times without luck. and i try to go in to bios multiple times until it finally worked then tried to change first boot device to usb stick. it worked but after the installation of it was done and the blue windows logo and loading screen came it stopped and went to the start i tried multiple times to install it again and again and nothing else happend. I try to make a usb 2.0 stick to boot device and tried to boot with it but now it is not even detected i have tried all usb ports on the computer and nothing works. Please help how can i get my computer to work again i want to install windows 10 home. Sorry for my bad english, english is not my mother language
https://linustechtips.com/topic/596421-help/
Where did you download the windows image from?
What software did you use to create that image?
Is it usb 2.0 ?
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/596421-help/#findComment-7748476
Is it usb 2.0 ?
I downloaded it from Microsoft site: https://www.microsoft.com/nb-no/software-download/windows10
Yes i did use usb 2.0
https://linustechtips.com/topic/596421-help/#findComment-7748602
Try it on an another computer? Looks like your motherboard may have some issues.
Tell you what, try to return the motherboard, they'll check if its fine or not.
OR
try installing another OS, a free one, ,like Linux, and see if its the motherboard's fault after all.
You could try updating the BIOS but dont do that unless you know what you are doing.
https://linustechtips.com/topic/596421-help/#findComment-7749345
