So I plug my xbox 360 controller in and it says this device has malfunctioned. So then I go look at windows update, no updates available. So then I go online searching for drivers. No drivers as I can see. This is the informationg i have and it would be super awesome if I could get a reply. Oh I also deleted the xbox 360 controller in device manager trying to disable and re-enable the driver, and I having a bad time getting that back.
over 9000 stream cores
https://linustechtips.com/topic/596186-360-controller-not-working-w10/
Just now, leelaa14 said:
You tried other usb ports? Also is it a wired controller?
reconnecting the controller to another port should bring up the driver again. Also rebooting with the controller disconnected and then connecting the controller after the boot should also bring up the driver.
10 minutes ago, ShadyHost said:
The wireless ones with the play +  charge kit won't even send a signal to the PC. @leelaa14
You can not use a wireless one with play and charge kit as a wired controller. You would need a wireless controller reciever. I got mine for £5
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
That didn't work
Just now, HalGameGuru said:
In device manager you might try telling it to show hidden devices and uninstalling all 360 controller related entries so it will try to redownload the driver
I'll just delete everything because that sounds like it would work :/
If you are using it with a play and charge kit then it won't work.
do you have any other cables to use it with. It might just be cable
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
2 minutes ago, zkt72 said:
Wired controller with a play and charge kit, seems legit
Sorry, I seen the post that said  wireless with play and charge kit. My bad
Just now, zkt72 said:
there is one and only cable, it is kinda attached to the controller....
oh im not sure what the problem is then
