CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£275.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.99 @ Novatech)
Motherboard: Asus MAXIMUS VIII RANGER ATX LGA1151 Motherboard  (£144.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  (£52.35 @ Ebuyer)
Storage: Sandisk Ultra II 960GB 2.5" Solid State Drive  (£183.99 @ Amazon UK)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive
Case: NZXT H440 (White/Black) ATX Mid Tower Case  (£90.42 @ CCL Computers)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£80.20 @ CCL Computers)
Monitor: BenQ XL2730Z 144Hz 27.0" Monitor  (£454.98 @ Ebuyer)
Other: NVIDIA GeForce GTX 1080
Total: £1309.91
Generated by PCPartPicker 2016-05-14 18:33 BST+0100
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744059
Total: £1309.91
thanks Me1bourne!
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744070
CPU Cooler: Corsair H115i 104.7 CFM Liquid CPU Cooler  (£115.24 @ CCL Computers)
Thermal Compound: Thermal Grizzly Kryonaut 11.1g Thermal Paste  (£20.94 @ Amazon UK)
Motherboard: Asus Z170-DELUXE ATX LGA1151 Motherboard  (£239.95 @ CCL Computers)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  (£54.99 @ Ebuyer)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  (£250.98 @ Ebuyer)
Storage: Seagate  2TB 3.5" 7200RPM Hybrid Internal Hard Drive  (£76.98 @ Ebuyer)
Case: Phanteks Enthoo Pro ATX Full Tower Case  (£87.95 @ Amazon UK)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  (£168.04 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  (£71.81 @ More Computers)
Keyboard: Corsair K70 RGB RAPIDFIRE Wired Gaming Keyboard  (£151.50 @ More Computers)
Mouse: Logitech G502 Wired Optical Mouse  (£71.33 @ Aria PC)
Other: GTX 1080 (£700.00)
Total: £2285.70
Generated by PCPartPicker 2016-05-14 18:39 BST+0100
The only thing that isn't in this list is the monitor and (optional) UPS. the thermal paste is the top notch that you can get in the market.
Me1... use air cooler sotution which is less efective than liquid as i put here with the 115i. this give you lower temps than air solution.
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744085
Total: £1309.91
are you able to find the htc vive on pc partpicker?
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744102
Total: £1309.91
You have a Freesync monitor with an Nvidia gpu. Also that psu isn't very good.
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744115
Something like this leaves you with just under £1000 for a VR Headset and new gpu. You could go with a cheaper monitor if you want a bit more money left over for the other two items.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£197.96 @ More Computers)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  (£111.96 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  (£55.98 @ Ebuyer)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  (£111.94 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£52.38 @ CCL Computers)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  (£57.01 @ CCL Computers)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  (£77.99 @ Novatech)
Monitor: Asus PG279Q ROG Swift 165Hz 27.0" Monitor  (£646.09 @ Amazon UK)
Other: Alpenfohn Matterhorn Black CPU Cooler (£39.95)
Total: £1351.26
Generated by PCPartPicker 2016-05-14 19:16 BST+0100
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744251
Total: £1351.26
Thanks for the build!
https://linustechtips.com/topic/595953-pc-build-ideas/#findComment-7744998
