USB Capture Card through LAN
Solved by manikyath,
the issue is those devices need the specific drivers for the capture card. not everything thats plug&play on your pc is plug&play on everything else.
the closest to this you'll come is something like a raspberry pi (or preferably something x86 with at least semi-decent encoding performance) and send it in a high bitrate stream to the receiving system that does further processing.
